Download LibreOffice 5.3: Writer, Calc and Impress
- 02/01/2017 01:05pm
LibreOffice 5.3, the 5.3 version of the LibreOffice suite, is available for download. This release includes new features and improvements for Writer, Calc and Impress, along with general updates to the open source office suite.
These general improvements are designed to make daily office work easier. The HarfBuzz-based layout engine helps documents display text more consistently across platforms. The revised help menu gives faster access to guidance and support resources. The improved import/export filters help when working with new MS Office documents.
Writer now supports table styles to apply formatting to a table that is retained when you make changes; a new Page Deck in the sidebar allows users to quickly customize page settings without going through a separate dialog box; and a new Go to Page Box enables users to jump to another page in the document with just a few keystrokes.
For users who prepare text documents, reports or long files, these Writer features can save time. Table styles help keep the same appearance after editing a table. The Page Deck makes page settings easier to reach. The Go to Page Box is useful when moving through multi-page documents.
Calc provides a new set of default cell styles, with greater variety and better names than in previous versions; in new installations, "Enable wildcards in formulas" is now the default option, rather than regular expressions, to enhance compatibility with other spreadsheet software; and a new text entry area allows users to narrow down the functions they are searching for, simplifying the search process.
In spreadsheets, the new default cell styles help format data more clearly. The default wildcard option in formulas supports compatibility with other spreadsheet software. The text entry area for functions makes it easier to find the function needed for a calculation.
Impress now opens with a template selector to provide users with a quick start; and a new Slide Properties Deck is now available in the sidebar during slideshow mode.
For presentations, the template selector helps start a new slideshow more quickly. The Slide Properties Deck in the sidebar gives access to slide settings during slideshow mode.
LibreOffice 5.3 has also been improved "under the hood," thanks to the work of hundreds of volunteers. This results in an easier-to-develop, maintain, and debug open source office suite. Although this work is not visible to users, it is extremely important for enterprise deployments.
